72ford250
- Joined
- Oct 16, 2013
- Messages
- 35
- Reaction score
- 0
Ok guys I am getting slightly frustrated with this truck. So anyways I bought a honey badger jr to replace the t500 as I thought I needed a little more flow. So before I took the t500 off I could hit around 2400 with 35% without turning. Next came the first Jr hpop it could hit 2200 with a 75% ipr and a DD tune from dyno proven. So I pushed for a replacement pump and got it this new Jr can do 2300-2400 with a 55% ipr as long as I ease into the accelerator pedal. So this comes down to a problem on my end I must have a internal leak. I have used a porta power to pressure each head. You can build to 3,000 psi and it takes about a minute or two to bleed off to 1000 psi is this normal? All upper o-rings on the injectors except one that I fixed seem to not be leaking when I dead head the hpop by giving the ipr 12v and cranking on the engine. Is it possible these rosewoods 160/80 with maybe 30,000 on them have bad internal o-rings?
