6.4strokin
- Joined
- Jul 3, 2013
- Messages
- 330
- Reaction score
- 0
What would be the best workstock setup for a 6.0 mainly fuel and turbo wise? thanks
So with all the supporting mods do you think I can hit low 600s and be workstock legal
I can get you set up with a turbo/injector combo deal that can easily put your truck into the 600hp range. You will need the supporting mods you asked about.
Full fuel system
Built tranny
205/75s or 250/100 hybrids
KC68 stage 3 turbo
Send me an email if you want some pricing
kcturbosinc@gmail.com
Should be able to if the truck is healthy and you maintain icp
I totally agree with this list but you could also look into 225/75 hybrids, just another option.
I don't get why you'd want hybrids cause they maintain icp. They way i understand it the achieve this by having lower injection pressure so wheres the advantage?
evidently 6.0 hybrids are different from a 7.3s? its the opposite for us.. hybrids are a shorter stroke so its easier to maintain and hold icp... im trying to learn stuff about the 6.0s as i have never cared to before..I don't get why you'd want hybrids cause they maintain icp. They way i understand it the achieve this by having lower injection pressure so wheres the advantage?
I 100% agree. They sacrifice injection pressure to maintain ICP... BUT... guys consistently seem to be able to squeeze out more power out of hybrids. Even though hybrids run at a slightly lower injection pressure... they still maintain a descent pressure, like 24k with hybrids vs 28k with conventionals.
For example: On a stock HPOP the max you can go on conventional injectors is about 600-650hp with a couple of lucky 700hp numbers. But there have been lots of guys with hybrids on stock HPOPs that have made it well into the mid 700s.
Jesse pushed the conventional injectors as far as they could go. Even with all the ICP he needed. He had to switch to hybrids to get more power out of his truck.
what i said above was for you too.
how does that sacrifice inj psi? if you maintain icp then inj psi shouldn't drop. bigger nozzles i could see losing some atomization of fuel but thats it..Yep. They are basically the same thing on a 6.0. Larger bore, shorter stroke (as opposed to conventional). Helps to maintain ICP better but you will sacrifice injection pressure.
Why do you guys think hybrids like spray so much?
Sent from my HTC One M9 using Tapatalk
Yuhpp, I was saying it sarcastically. Well put.Lots of fuel with hybrids, and the poorer atomization doesn't matter when you use nitrous since there is less need for good mixing of the fuel/air.
