Injector o ring ?
eng53ine
Ohio
Just need to if the rib on the little copper washer goes up or down on the tip.
Thanks
Jomax
Arizona
It goes down so it presses against the injector cup
Dmstrucks02
Pearland, TX
Only picture I have on a set I took out. It's a screen shot so not great quality
eng53ine
Ohio
I couldn't tell by the ones that I took off or by the write up from riff raff.
I put the two ribs down to the cup, like the one on the left in the picture.
Jomax
Arizona
You wanted the one on the right to go down into the cup. That's how all the reman injectors I got have been.
I don't know if doing it the other way hurts anything. I'd call an injector builder Tuesday and Ask.
eng53ine
Ohio
Will do hopefully it don't matter since it's just a compression seal but I guess I'll wait and see
DEEZUZ
NO PUKESTERS
NWI
I always put the double side down so it seats against cup
eng53ine
Ohio
Guess I'll just torque them down and see what happens. The ones that came out were flat so I reckon they'll smash either way.
Thanks guys
Arisley
Arlington, Texas
When I did my injectors, to be perfectly honest with you, I didn't even pay attention. Unless I got lucky and installed all eight correctly, my guess is that it doesn't really matter. There may be a "preferred" way to do it, but I bet wither way will work.
webb06
Seneca, MO
There's no special way. It's going to compress and seal either way.
eng53ine
Ohio
Ok thanks guys, and my best to you and your wife Andy.
Arisley
Arlington, Texas
Bet it actually came out pretty easy. I have actually seen more come out easy than fight you. Usually all it takes is a sharp pick to grab hold of a little bit of metal and turn it out. If that doesn't work, a left handed drill bit will work wonders.
eng53ine
Ohio
Yeah I hit it with a left handed drill bit, I don't think it needed it a pick spun it right out. Broke a spout as well. Got everything torqued with the help of a babysitter lol, hopefully be able to start cranking it over tomorrow evening.
DEEZUZ
NO PUKESTERS
NWI
Never re use a copper. Their designed to be crushed once and that's it
