Injectors, airdog, reg return?
Skinny
British Columbia, Canada
Ok so the diesel gods must be liking me i have the oppertunity to try a companys new 100hp injectors... I havnt heard the cc's on it yet but im thinking they are 190s... i know i will need a fuel system but what airdog or another company to use and reg return..i dont think the blue spring and 6.4 banjos are going to cut it?..:shocked:
Mdub707
Mohawk NY
I'm always scared of any company that advertises 6.0 injectors by HP rating.
Are they being built from new cores or what?
If they're about a 190, I'd just run an AD150 feeding the stock pump and a dozers RR, stage 1 would be fine I'd imagine. A sump wouldn't hurt either.
MorganY
college station, tx
be sure your stock pump is healthy, otherwise the ad 150 won't do a damn thing. It only runs at 10psi, so if your stock pump is bad, you've just spent 550 for nothing
Mdub707
Mohawk NY
Exactly, and I read more and more every day about people having issues with the AD2, some guys taking them off of their trucks now. The killer setup would be an AD150 feeding a fuel lab or A1000, pulling from a sump and then feeding directly to the heads via a y block.
MorganY
college station, tx
I've seen all pumps die, a1000, fuel labs, and ad2's. My ad2 has been running fine for a year now...but I do have an extra pump behind my backseat in case LOL
Mdub707
Mohawk NY
Anyone heard or used the edelbrock pumps? Someone was telling me about one of them the other day.
windrunner408
This describes my setup exactly and it works great. I think though that the AD150 with a sump and RR kit will do just fine with injectors that are roughly 190cc in size. Best of luck man.
Agjake11
Rosenberg TX
AD150 is also not necessarily required if the OEM pump is doing fine. I have a friend that did warren 190/75 and dozers stage 1 RR with OEM fuel pump and is doing just fine. how long he can last like that... only time will tell.
SSpeeDEMONSS
6mi from the beach, SoCal
you can run the AD2 as well, either way works fine. I like feeding the stock pump because if one pump goes you have a backup, had it happen before
I understand the logic in your thinking but this doesn't make much sense. If the stock pump dies I certainly hope you don't try to go far at all with only 10-15psi of fuel pressure. Though if the airdog dies you should be able to get somewhere with just the hfcm.
Garrett
encrypted with an enigma machine
MorganY
college station, tx
Garrett
Yes, the fail safe would be if the Airdog fails, not the other way around. That's also why I mentioned he make sure his stock pump is healthy before he buys the airdog or else he will be spending $900 on pumps.
Mdub707
Mohawk NY
Couldn't you adjust the AD150 up to 55ish psi with a spring swap in an emergency to get you home though?
