injectors for my 94
94TurboDiesel
Wisconsin
Ok so I found a set of AO injectors for my 94. this is probably a stupid question but these will work for my truck right and are these injectors even worth a chit I figured getting them at such a good price i could have em rebuilt an bigger nozzles installed. any info would be great thanks
94TurboDiesel
Wisconsin
Thank you for the info. Im still learning the ins and the outs of these motors an just didnt want to screw myself by buying injectors i cant even use
superduty4x4
Newport, WA
You can drop any injector from a 94.5-03 7.3L into these engines, and some of the IH engines uses the same injectors as well (T444E, DT366 and others I'm forgetting at the moment). What will get you is if the injectors are split shots... you'll need custom tunes to get them to work correctly just as you will with modified injectors.
