Installed Some Rigids
Powerstroked162
On Da Juice
Wa. State
Hands down the cleanest light bar in bumper setup I've seen on a 6.7 to date. Fog lights look clean as hell too! Nice work man
Daddyusmaximus
That 40" bar is killer bright. I have 4 of the Duallys on my bumper and they really light up the area. I can only imagine flipping on that bar on a dark country road....
South Florida
The D2 are super bright. I would put them on the same brightness level of the 20" E series that I had before.
I am working on putting together a bracket/wiring kit to sell with the Dually packages for 11-14 Super Duties.
Timmy42
I have the same truck in white did you have to use the cradle to mount the 40" or did you use the bolts by the tow hooks
South Florida
I returned your email.
There is no cradle needed. You will use the two brackets that come with the 40" bar. you will need to get a couple of stainless nut/bolts and thru bolt them using holes that you will drill yourself. It does not use the tow hook bolts.
