Charles
- Joined
- May 18, 2011
- Messages
- 2,729
- Reaction score
- 47
Anybody know the deal on the 02 instrument cluster not having a volt meter? For me this is unacceptable. For the past 15+ years, the first place I look when I key on is the volt meter, but like so many other things in this world, those making the decisions decided for me that I didn't need my volt meter anymore on the 02 cluster. Instead I get a completely worthless trans temp gauge I could give not a single damn about if I tried all day.
So....
Seeing as rpm, oil pressure, water temp and volts are the building blocks of instrumentation on a water cooled diesel, I want my G'damn gauge back. Tired of every batt light flicker leaving me wondering if I'm slowly losing charge, whether it's putting out at all.... when do the glow plugs turn off, are they still on, did they even turn on.... just tired of not knowing the vehicle voltage...
I know at least one 02 with a manual trans has a volt meter in the cluster. Do they all? And can the instrument cluster be swapped between auto and manual in an 02 without ill effect?
Lastly, can I reset the digital odometer after the fact to read appropriate milage?
So....
