intercooler 6.0
Duradan
Redding, CA
I installed a 6.0 Intercooler in my truck, used to make 42 lbs boost, now making about 34 lbs... is that cause of the denser air?
KBMKVIII
Texas
ten pounds is a fair ammount. i think i lost 5-6 lbs going from no ic to 6.0 ic my self.
golfer
you might want to pressure test the system...
the plastic end tanks on the 6.0L coolers don't hold up to well with higher boost setups...but if no leaks are found..just enjoy the cooler/denser intake charge.
AllanB
Mississippi
If anyone is interested in buying a 6.0 intercooler. I have one I would sell. Complete with piping.
always-strokin
8-10psi seems too high for an IC install. I'd think its closer to 4-6psi.
Check for boost leaks w/ a leak down check.
