Intercooler Questions
'94IDITurbo7.3
Fowlerville, MI
Are the IC's in the vans the same as the truck's coolers?
What all is needed to remove the cooler from the van? the van is in a junkyard.
Thanks
'94IDITurbo7.3
Fowlerville, MI
Thanks for the input!
Do you know the size of the van coolers or how they are different?
I was scoping it out yesterday and it didn't look to terrifying to take out. junkyard makes it a bit easier b/c you can just kind of push crap out of your way lol.
'94IDITurbo7.3
Fowlerville, MI
Big Angry Hillbilly
I don't know the dimensions off hand but it is significantly smaller.
And I guess at the junkyard it's probably not a bad pull.
If I remember rightly if you are planning on reassembling the E van rad stack and not removing stuff that's in the way with a sawzall... You have to pull the whole stack as an assembly. I seem to remember this being the easiest way of doing it.
