International water pump/filter
Big Bore
9000ft in the CO Rockies
Where are you guys getting these? I've decided to use one for my build. I have the remote filter setup, but I don't like where it is and want to clean up the top of the engine compartment a bit.
Tom S
I came across a Car Quest catalog on the web Haldex pumps so that might be a place to look. Look in the Navastar Section not the Powerstroke one.
  • HWP_Haldex_Water_Pump_2010.pdf
TrailerHauler
Michigan
The pump with the incorporated coolant filter on the med. duty engines is a nice setup, definitely something to consider if the water pump ever has to come off!
NEVRNF
NW IL
Here are the IH part # for the change. I got these years ago from TDS and i am not sure IF the bolts are needed
Pump 1831676 C92
bolt (3) 1817958 C91
bolt (2) 1817811 C1
bolt (4) 1818693 C1
