Irate LPFP
CT9AIX
MA
Seems a little expensive if you ask me. Can basically build your own and make it 100% custom to your truck for cheaper. A1000= $350, aluminum filter heads from CAT/Donaldson=$50 (for 2), CAT filters= $40 (water separator and regular filter), -8 Parker Push Lok hose is cheap as hell and the steel fittings are too. Factor in small pieces of aluminum angle iron/flate plate and you might have $600- $625 into it. This is based apon just what's showed on Irates website from that link.
CT9AIX
MA
I can find a few part numbers for you tomm from when I built my LP system. I went a little different route and used a Fuelab pump so I won't have all the numbers you need, but enough to get in the right direction. Another thing, like mentioned above you'll need some sort of FPR. Don't know if you already have one or not, but that will add another $150ish if you need to buy one. For now here are a couple quick links:
http://m.summitracing.com/parts/aei-
http://www.parker.com/portal/site/P...extdiv=687909&vgnextpartno=801-8-BLK-RL&Wtky=
https://commerce.cat.com/en/catcorp/fuel-water-separators/175-2949
https://commerce.cat.com/en/catcorp/fuel-filters/1R-0750
