Is P160A the warranty killer?
UNBROKEN
Apparently if you've tuned you have this code hiding. It won't set off a CEL but it's always there and can't be cleared (maybe an IDS?). I see it on my CS every time even if I clear the codes.
Is this what Ford looks for to deny a warranty?
Powerstroke Man 6.4
I never ever seen it pop up any of my buddies 6.7s that were tuned.
I got this from another site.
"There's a parameter you have to reset with the IDS and it will clear everything learned in the past including that code."
UNBROKEN
It won't light up the dash. You have to find it with a scanner or monitor. I'd like to know if people with CS's and CTS's are seeing it also.
02bigstrokin
I was seeing it with the canned sct tunes I ran first. Then once I went to the street max tuning that code went away.
UNBROKEN
Could be? There's some threads floating around on various sites about it but I didn't look at year models.
Powerstroke Man 6.4
Looks like Ford started to put that code in the 11's maybe certain tuners/tunes set the code off and some don't?
