Just doesn't add up
P.I.S_7.3
TAMPA FL
Dynod the truck today. Only hit 402hp. How is this possible with my mods. Every post I see with similar mods to mine is 500hp +. Dyno was a mustang 1100. Truck boosted to 43psi
238/200% injectors
38r turbo
Full fuel system holds 65psi
Srp1 holds 3100 psi
Tuned by jonathan at no limit
Studs
Springs
Suncoast tranny
Can some one please tell me wtf the problem is
P.I.S_7.3
TAMPA FL
If its not enough air then how is it every thread with 238s and a 38r hits 500 damn near every time at 450-475
P.I.S_7.3
TAMPA FL
Ran atleast 7-8 times number never changed. Yet my track times say more power than the dyno says
seeyalater5.9
Giddings, Texas
238/38r is stretched out at 500+HP...
IMO it's a ~475hp setup
CSIPSD will agree with me as well.
Far too many of y'all throw the "all mighty" 38r with 238's and expect 500+ like nothing.
OP, you def should of put down more than 402hp though. We're you able to fully spool up? What were your gauges reading? Like others have already stated...too much injector;too little turbo
smoker00
Winnemucca NV.
Mite try a different tune just to see if it changes.and maybe a different dyno. Im no expert at all but that seems low.. my 175/100 along time ago did like 4 something at 4700 ft. The good thing is your track times put you over your number by a bit. Track time are what most of US care about any ways.
Powerstroke Cowboy
Montana
How smoky was the tune you used on the dyno?? You should be well over 400 HP even with the 38R. besides the dyno might not have been set up right.
