Just got a 6.4 that needs engine work
protraxrptr17
Number 2 cylinder has no compression. Huge amount of blowby, smoke and throwing number 2 contribution code. I pulled the injector (it's brand new, maybe somebody tryin to fix it) and looked inside with a borescope. Piston looks to be intact. High pressure turbo looks to be shot also. Looks like I will be doing new pistons and turbos. I gotta go budget on this truck. What should I get? Don't know a lot about 6.4s. I will be doing all the work myself. It's been DPF deleted, but the tuner didn't come with it. Egr stuff is still in place. Looks like some kid or redneck owned it before. Had stacks at one time, but they chopped them off right under the cab. What's left looked to be a really nice stainless exhaust at one time.
I also have an 06 6.0 that I have a done a few small mods on. When I get the 6.4 fixed, I will have to sell one of em. Cant afford to keep two. I really like my 06, so this 6.4 will have to be really good to make the cut. I have Innovative tunes, 5" exhaust, 03 turbo, tuned FICM, 6" lift and 35s on my 6.0. It has new paint. It's a lariat with almost every option. Has a ton of miles, but I swapped in an engine that only has 100k. Body is real straight. I know that it does nothing for performance, but I love the way it sounds. Is there a turbo setup for 6.4s that sounds as good as an old 6.0? I plan to get it running and drive it a little while, then make a decision on which one to keep. The 6.4 is a CCLB with a 6" lift and 37s. Has a really gaudy road armor front bumper. It is a lariat also but it doesn't have few options that my 06 has, such as heated seats, up fitter switches, and power back glass. It is scratched up a little bit. I really like the newer interior and front end of the 08.
TY'S08FX4
Ontario,Canada
If you're doing pistons id go with a set of hd pistons out of the maxxforce 7 motor from international. RCD, elite, Midwest diesel and a few other vendors on here sell them they usually run around 1000 for the set, 1500 if you want them ceramic coated and valve relief cuts, would also do arp studs while your in there. The closest you'll get a 6.4 to sounding like a 6.0 is with a single turbo kit, some budget kits can run around 2k, most guys on a budget just run a 71mm drop in atmo turbo and leave it like that, would put it somewhere around 620-640hp depending on the truck. Good luck with your build!
KBMKVIII
Texas
That's mean! And I thought my 6.0 sounded like a jet... that sounds like youre behind a 777 during take off... and only at 1/8 throttle hahaha
protraxrptr17
Yeah, that sounds awesome, but it still doesn't have that ear splitting scream like mine does. What setup do you have? I could definitely live with that.
About the pistons, what are the advantages of the maxxforce pistons? Have an international part number? I got a decent relationship with my local dealer.
powerstroked08
Pennsylvania
I have the tow power x's. And they are fun! And the thing is the maxxforce pistons are usually called HD pistons and they are built stronger than the powerstroke oned ford uses. The biggest thing to my understanding is having the pistons cut(delipped) to have a straight wall. This greatly reduces the chances of cracking a piston. Several guys have great luck with stock delipped pistons for moderate power levels.
drunk on diesel
the International pistons are already "de-lipped" straight from the manufacturer. De-lipping Ford pistons is modeled after the changes International made to the pistons
