king 3.5 lift coilovers
Big&dirty
Anyone had expiriance with king shocks? What are you opinions onthe kit even if you havent used it
Cutting-Edge Diesel
Newkirk, OK
That's not a kit it's only the shocks.
Kings are awesome tho. I run them on one of my trucks. Look into carli lifts if you want a suspension System with king shocks
smokinstroker
Texas
I've seen them and been in a truck with them. Ride was decent. Nothing better than an icon or carli coil spring kit.
With that short of a coilover you lose travel out of your system as well.
Matt's correct here. Those are only the front coilovers and rear shocks. You will need a block for the rear, u bolts, possibly sway bar links and adjustable trac bar to keep everything on track.
Carli uses king shock bodies but the valving and internals are modified in house by Carli. In retrospect you are only getting the body and the shock shaft from king.
If your stuck on a coilover, look at carli suspension, they have full kits in 2.5" and 4.5"
