Largest tire on a dually
DMDP
Harford County, Md
My '15 350 Dually is scheduled to be delivered next week. Going to try and hold off on tuning it for a little while, but I gotta get some nice rubber under it. What's the largest tire guys are fitting under a STOCK height dually? Camper package and 17 inch wheels. I don't mind buying spacers for the rear tires, just don't want to get into lifting it right now. Any pics would be awesome. Thanks
ftast350
You could get away with 35s with some minor if any rubbing on the front and might need a 1/2" spacer on the rear between them.
MEDIC350
Michigan
35 12.50 will fit with possible rub in the front but a lower coil spring spacer will solve that ( easy to install and cheap to buy) but you will need a 2" rear spacer with that size . 285/75/17 will fit with no spacer and no rubbing with stock hight
DMDP
Harford County, Md
when you say minor rubbing, where? cab pinch weld, fender, or bumper? my 6.4 was leveled with 35 12.50s on stock 18's and it rubed on the radius arms slightly when turning sharp which im not worried about
B.Warning
NE Missouri
Tires are not going to hit the frame. They might rub the radius arm. You'll need to trim the inner fender, massage the bottom section of the fender a little, and you'll be fine. To clear a 12.50 tire on the rear with factory wheels you'll need a 2" spacer between the duals.
HPGod
FYI. 295 60 20's clear on Eagle wheels with no spacer.
14ccd
The SRW trucks come with 275-65-20 from the factory so i would assume that these would fit on our duallys, obviously you would need 20" wheels. That's my plan any way. As far as stock 17's, tires up to 285's will fit but I just dont like how they fit on such a narrow wheel.
DMDP
Harford County, Md
Got the truck! Didnt know it was coming with the wide track front end (which is awesome btw). Does that change anything with tire fitment? Ive been taking some measurements but really want to hear someone say "yes I have ran them". Im really against doing any triming of anything to make tires clear. Im leaning towards the Cooper S/T Maxx, 295/70r17 (33.23 x 12.0) and 2 inch spacers in the rear.
pwrov1
I'm in the same boat, have the same question as the OP. Any new info or pix? Thanks.
14ccd
That is a really wide tire for a stock wheel. How are they wearing? I would be afraid to pop a bead on a hard turn.
