Leak From OEM composite Upper Intake Manifold?
harrelljr99
I noticed a small amount of black oily fluid where the upper composite intake bolts to the manifold on the left side? Any info on the cause and what it is leaking from there ??
Six_Sloww
Southeast MI
Crankcase vapor - basically oil and condensation
You might have to replace that oring under the intake if it's leaking ccv vapor it's probably bleeding boost as well
Sent from my ONEPLUS A6003 using Tapatalk
Six_Sloww
Southeast MI
It doesn't look like it's a big leak otherwise it would be wet with oil. It'll probably get worse over time and you'll just have to replace the o ring
harrelljr99
Is this a common issue? Has anyone else experienced this?
Lipka101
Maryland
It’s hardly an issue. Just take it back to ford and tell them to fix it or spend the 2$ and 7 minutes to fix it yourself. Hell, check the bolts, probably just need tightened.
Sent from my iPhone using Tapatalk Pro
