Leaking coolant from back of head.
ghohouston
Lewisville,Texas
Id hook a gauge up to the coopant resovoir and see how much pressure you build. But you see how high up the leak starts? Looks like the valve cover gasket is leaking to me
ghohouston
Lewisville,Texas
Just went back and re read, so you are losing coolant, have you verified you dont have a leak in the valley thats dripping down somewhere? Or a heater/coolant hose leaking
webb06
Seneca, MO
Are you sure it's coolant? I'd do some more looking. Maybe pressurize it and see if the hose directly above that area is split or leaking
Pwrcummins
I smelled it and smelled kinda sweet. I'm gonna warm it up here shortly and see what happens.
reilly8282
My egr delete leaked as well, run your fingers on the bottom of the U-pipe that connects the intake to the oil cooler. Mine was leaking from the fitting in the intake manifold.
Pwrcummins
Heater hose from coolant filtration was leaking. Thank god it's not blown heads (knock on wood).
Pwrcummins
So am I. Thanks for the help guys. I about messd myself if it was head gaskets. Lol
