99powerstroke
- Joined
- May 18, 2011
- Messages
- 107
- Reaction score
- 0
I have noticed a small leak coming from what looks like the lower water neck that then connects to the lower radiator hose. It looks to be dripping from the lower bolt that bolts to the water pump. It only does it after sitting not right after I drive. I had the water pump replaced last year or year before and no problems with temp. Just annoying drips on the garage floor.. Do you think I could just try and tighten the bolt alittle? I have looked from up above and nothing looks to be leaking anywhere else just the lower bolt. Oh and it's only 99' F350 7.3
Thanks
Thanks
