leaking up pipes
Old OutLaw
Suthren OryGun
if you have a lift, or access to one, the easiest way is just jerk the tranny, thatway, you can get at the whole mess and do a good job....
and if you don't, it's a complete PITAZZ
littleredstroker
where the antelope play
I pulled the turbo , did pipes, and installed in way less time than it takes to pull a trans I thought..4-5 hours or so. I also have 250ft of extensions and a friend to come help
sent while needing more cowbell
Old OutLaw
Suthren OryGun
4-5 hours ? ...LOL it only took my guy about 3 hours...without pullin' the trans..
least that's what he charged me for 3 hours....but he's young and a pretty good hand..... it would have taken longer to jerk the trans out, but it's a lot easier to do......
Arisley
Arlington, Texas
If the book says three hours, you pay for three hours. If it takes ten hours or twenty minutes, you still pay for three hours.
littleredstroker
Good for your guy. Guess what I paid to have my uppies done ... $0.
Chalk one up for working on your own ****
jaybuller
I hate pulling the trans on my truck. 2 driveshafts, tcase, crossmember then all the bolts holding it to the engine. I would much rather fiddle around it than pull it.
Arisley
Arlington, Texas
4WD does make it more time consuming. Working on the ground with the front wheels on ramps, I have had mine out in less than an hour before.
99powerstroke7.3
Good ole Plainfield Illinois
so a little update before running to sears for some tools i got @ out of 4 out of the Y cant see how possible the other 2 are possible with the pedastal in the way so i went ahead and started to remove that as well
