Lets see your LED light bars
CrossTx
Do you have pics of what you had? 2 40"s looks sick btw.
I have one somewhere
I will post it as soon as i find it
Im thinking about throwing it on my boat tower if i dont find new mounts. I might have to have them made. I think if i have it below roof line or close to it it will help because the one on my raptor did not whistle as bad.
Any other roof mounts whistle?
Cknox121
Augusta GA
do the brackets come with the 20 inch lights like the one from pse or are you guys making your own?
Here is how I did mine. Perfectly centering in the opening. Just used some metal I had laying around.
Sent from my cracked iPhone using Tapatalk
powerstrokin15
Charleston, WV
I'll get pics. but I welded two small pieces of angle iron to my tow hooks on each side then that gave me a flat surface to mount on with the mounts that come with our lights
Eric@HoldersDiesel
forcefed6.4ford
Medicine Hat... Again
Yeah. Something has to be fabbed up to make it work.
A nice thing about the fog lights is that they can be wired directly into the existing wire harness. No need to use the supplied switch and leads. Just cut the factory connection off and splice it to the rigid connection. Dead simple.
beanz15t
el paso tx
33" in grill (copied idea from another owner on this forum)
This was a project but end result was worth it..
Riverside
southern Oregon
They have a pretty good focal point.
But they are way to bright for on coming traffic.
That's why I have the spots and the bar wired to a solenoid.
I give power to solenoid via #1 up lifter switch.....that solenoid is tied into the hi beam wire to the headlights that acts as the trigger for the solenoid.
All that means is when the up lifter switch is on the bar and spots turn on and off with the factory high beams
BigNiner19
South FL
What brackets do you guys use to mount a 20" in the front bumper of 08-10 ? I cant seem to find a bracket. Do you just fab something up and use existing holes ?
