Lets see your powder coated engine parts!!!
UNLIMITED_DIESEL
Bremen, Ohio
Trying to get ideas for my wife's engine build. Thinking silver vein powder coat on block and heads, then a purple translucent on intake, compressor covers, oil cooler cover, valve covers, etc.
Thought? Suggestions?
black6.4
Silver vein is nice but you wont be able to see it after everythings in place...you cant hardly see me valvecovers under all the garbage...silver vein also looks good covered in a translucent color.also if you do your intake it will have a rough texture due to the casting if you spray it while hot it will look better
UNLIMITED_DIESEL
Bremen, Ohio
Thanks! I have a friend who is doing the powder coating. I know we won't see a lot of it, but I'll feel better that its coated and not just painted.
Spatel23
Olive Branch, MS
I once owned a nice 6.4, she pulled off motor shots quite well......
kinda dirty in this picture, but you get the idea
thuglike
Linden, NJ
how do you like that BOV?
It took some time to get use to it. I had to figure out how to drive the truck so it would not activate all the time. Like in traffic, getting in and out of the throttle.....you need to finesse the throttle if you do not want it to blow off.
Once you get that down...it does it's job. I like it.
Erikclaw
Central CA
If it blows off that easily, you have it set too sensitive. Makes it more dangerous than helpful. Having boost blow off when you need to move isn't good.
