Leveled 06 F350..what tires?
Myerswelder
Greentown, IN
I just got a 2.5" leveling kit for christmas and am needing new tires. The wheels im gonna run are 20x10 -19 offset and 4.75" backspace. What size tires can i fit with minor trimming. Im looking at 295/60 trail grapplers. Are 35 x 12.50 gonna be close to fitting, found a deal on toyo mts at a local tire place that have 30 miles on them. I dont wanna lift it in order to clear tires. Thanks for the advice!
smokedout250
harrisburg oregon
07 on 35x12.50 20x10 with -24mm offset
Big&dirty
Do you think E=smokedout250;869215]07 on 35x12.50 20x10 with -24mm offset
Sent from my iPhone using Tapatalk[/QUOTE]
Do you think you would have enough room to run a 20x2 wheel with you setup also what leveling kit do u have
Joe_strokem
Franklin, TX
No sir. The tires do barely rub the arms on the axle. But only if I turn it as far as it will go.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Joe_strokem
Franklin, TX
I'd walk outside and get ya some more pictures but it's at the shop having the motor completely rebuilt.
