Leveling kit 2015 f-250
sixpointoh03
I just bought a 2015 F-250 how much do I need to lift the front to be level with the back. From my measurements it seems like a 1.5 would do it but I have people telling me to do 2 or 2.5 in the front. I don't want the back to sit lower than the front just trying to get some opinions from people who have installed leveling kits
Thank you
20156point7
Tazewell,VA
I have the icon 2.5 kit with 4 inch blocks in the back and it has about 1 inch of rake. 2.5 with 4 inch blocks is perfect to me.
CMCx2012
Long Island, NY
I wanted to have a slight rake as well. I chose the full Deaver/Carli spring pack out back for mine, so we will see the end result once it is installed.
UNBROKEN
My 2015 F250 with a 2.5" over spring spacer in front and 4" block in back is dead level.
These things are just all over the place.
sixpointoh03
I'm thinking about just doing the 1.5 ready lift spacer in the front hoping that will get it level for now until I can wear the factory tires out the ill go with the full carli pintop loft and get bigger tires.
UNBROKEN
I've got an Icon 1.25" under spring spacer sitting here you can have. I got it from another member for free and told him I'd pass it on to the next guy that needs one. It's yours if you want it.
UNBROKEN
PM me an addy and I'll send them out today. It's just the spacers and bolts....pretty self explanatory install....just get everything loose and slide it in between the axle and stock spring locator and bolt it in.
PTSUPERD
That's whats up. Nice.
ftast350
I've done the 2.5" with 5" rear blocks keeps a small amount of rake but looks the way a truck this size should! Look into doing the radius arm drop brackets aswell as with the 2.5" it somewhat increases the "bump steer" very minor!
