levelling kit questions
Dmstrucks02
Pearland, TX
i think i might rub bad i have 20x12 -44 and i had to take the bumper off so I'm hoping that the x codes will work might have to do little trimming.
Yea I rub on the drivers inner fender a little
You're going to stick out another 1.75" give or take...
mattl140
canada
got x codes new u bolts. will i be able to reuse the 2 bolts that holt the spring in and when putting the springs in will i need to unbolt the trac bar or will i be fine with just doing one side at a time. thanks
Dmstrucks02
Pearland, TX
I took the trac bar out, or unbolt it..
Lower the axle and support it with jacks- I have 2 floor jacks, you might want to support the Pinon as well to keep it from rotating
Hang the new springs and move the axle into place with a floor jack
mattl140
canada
ok thanks man and what about reusing the 4 bolts that is if i don't have to cut them.
