Lift/Level Sway Bar Ext. Bracket or Links
6.7Stroker
Hey guys,
In a slight pinch. I really would rather do a 3.5" small lift on my 2012 F-350 instead of a 2.5" leveling kit. I see on the 2011+ trucks they give you sway bar extension brackets instead of extended end links. My only problem with this is I still want to be able to plow my driveway with my Western Plow with Ultra Mount. If I put the sway bar extension brackets on, it won't work with my plow mount. For a 3.5" lift, will I really need the sway bar brackets or will it still work ok without extending it down? Does anybody make extended end links that I can use rather than the extended brackets?
Thanks!
