Trying to chase down an on going issue. Trans shifts/locks up normal under 0-100% throttle BUT the truck is reving at 99mph under full throttle, once I let out of it and coast back down I can feel what I think is the converter locking back up at 80-85mph. At 99mph the truck will still pull if you stay in the throttle but its just not near as hard as I know it should. I think this may be an solenoid issue as the truck has shown a code in the past but does not regularly throw the code. I will also say 30% of the time the truck will lock in and pull like crazy above 100mph.
The only other symptom I have is when rolling into the throttle after lockup (46-55mph) the truck will sometimes come unlocked then re-lock shortly after.
I have myself convinced that I should swap the tcc/od/intermediate solenoid - whats everyone else think?
Sorry if I'm a bit unclear - can be hard to get the issue across via text.
Thanks.
Thanks.
