Looking at a 7.3
Hilltop
Texas
I found a 01 F350 EC 2wd auto with 300,000 on it. Starts good, runs good, no warning lights, trans shifts good, AC not as cold as should be. Has an oil leak, been leaking a while I'm guessing off the back of motor so maybe an oil pump issue? Has a little gray smoke when running. It was a trade in and the dealer said I can have it for the 3000 he gave the guy for it. Trying to decide if its worth it. Opinion?
Pstrke96
Dunnellon fl 34433
Wouldn't even blink I just bought a 97 with 138k and a leaking oil pan for 2800
Hilltop
Texas
Well I missed it! Going to look at another one tomorrow, it's a dually which I really didn't want but it's 5000 and looks like a nicer truck with fewer miles.
Dirtclod
Pilot Mtn. NC
Do your research on these. They're good engines if they've been serviced right and treated right. Do you know how to check blow by? Be prepared to spend a little money if it hasn't had updates like suspension,bearings,seals in axles etc..... lots of good info on here. Good luck happy shopping!
dmd
Denton, TX
Common leak is from the turbo pedistal on the 7.3. Stock turbo?
When it is running pull off the oil fill cap, some even escaping vapor is OK. If it is chugging like a freight train then walk away, it has a bad cylinder.
Pstrke96
Dunnellon fl 34433
Thank you sir, I put some rubber on it and towed my 38' trailer 12k # 600 miles through the hills of tn and kentucky it didn't miss a beat
