Strokin6.0
Ive got a 2004 6.0 holds pressure while drivng down the road but loses pressure at idle, in the process the turbo sounds like its rumbling.. ive changed the pressure switch and thats just because i hooked AE up to it and it pulled the code for it, nothing changed with new pressure switch :fustrate:AE showed everything to fine and working good.. ive also checked the valve in the oil bowl its working fine.. The truck is showing no signs of leaking oil anywhere, ive read some posts about the hpop and lpop and if they were bad the truck wouldnt start, mine starts and runs just doesnt hold pressure, any advice would be very very helpful.. thanks for your time
