lots of 6.0 parts, engines, trans, oem hg's,ficm and more
speedracer1000
everett, pa
some f and e series parts. mostly 05-07, most small items prices are shipped. inquire with needs
ficm, strong 48volts-200
used injectors- 85 shipped each
05 f series 5r110 trans harmess-100
6.0 engine mounted vacuum pump, mounts in front of the drivers side lifting hook, sell as a kit hardware included-180
oil/fuel filter housing-65
140k mile long block-1200
5r110 190k-350
used good alternator-50
up pipe-75
esof t case-200
04+ pedastal-40
throttle pedal-35
fan with clutch-150
ford oem 18mm head gaskets-270
fan without clutch-80
fuel pump-50
like new radiator- 80
visor-40
7.3 manual shift t case-200
hpop cover-40
hunterER7
Where you located. Interested in ficm.
