Low boost fueling on the H&S mini max
powerjoker12
Nebraska
I have the H&S mini max with HD300 tuning on my 2008 6.4. My low boost fueling is currently set on 2 is there any benefits from turning it up more or turning it down?
turning it up wastes fuel economy makes makes more smoke. that much fuel at low boost is hel! on your conn rods and head gaskets. 2 is the max i would go;
powerjoker12
Nebraska
I have head studs but don't wanna hurt the pistons and connecting rods. I had it on zero and the throttle response sucked. I didn't know were the best setting is for throttle response and not completely killing the fuel economy.
twitch02x
Houston
I had it at 5 for a year then put it on 0 and truck drives better and hardly smokes at all
powerjoker12
Nebraska
After turning it up to level 2 the throttle response is way better but its smokier also. I turned it on 5 for a day was way to much fuel for stock turbos.
did your custom tunes not work out for you?
try gearhead custom tunes-responsive and clean with more power and waaaay better shifting than canned tunes.
Heavyhaul
Wyoming
Dustin and Mike did some dyno work with the low boost fueling and determined that the turbos spooled faster with the setting on zero and produced better results.
powerjoker12
Nebraska
Well you guys definitely answered my questions and I will definitely be buying some gearhead tunes soon. Thank you
