Low Boost with BD thruster 2 Installed
Stoneman
British Columbia Canada
had a bunch of upgrades done on My 2000 7.3 Powerstroke and not Happy with Performance, Had the Injector cups done, 4" MRBP Turbo Back,BD Thruster 2, SCI Live Wire, Warm up Valve removed. Bigger intake, new Up Pipes, All new Boots and Clamps, Presssure Regulator Changed.WOT Only getting 11psi Boost at 3700 rpm.This was done in Performance setting on the SCI. Anybody have any thoughts. Shop I had do it pretty Reputable, But Closed until Monday. Thanks Rick
Jomax
Arizona
Disconnect the wastegate red hose and slide it into the Intercooler boot clamp stud. This will check to see if the waste gate isn't properly adjusted.
Mesa, AZ
You may have a map sensor not reading right or something. 1150 egts is pretty low for not having any boost. Try checking with a mechanical gauge. Also make sure the map hose isnt kinked, cut, or plugged, as well as the map port on the intake. May want to check map vs ebp and baro koeo to make sure it is reading right, should be damn close to what ebp and baro are koeo.
