smokinstroker92
I have a customers truck kicking my ass i need of some advice
Start with the history of the truck started out just studded and ****** it blew the gaskets went back with new studs and oringed the head. At this time i installed warren 205/100s barder, Barder stage 4, RCD thumper 1 hpop, regulated return, fuel system w/ fuel lab pump, ported intake mani, etc. It also has a 58v ficm and the possibility of some ficm tuning but the customer nor i know what it is.
The truck has had a icp at wot problem since the work was done. The injectors have been back to warren and now have upgraded solenoids. The pump has been back to rcd and supposedly tested as well. The truck would only hold about 2.5-2.6v of icp at wot which is wayyy low and will max the ipr DC as soon as you go wot.
Now what i have replace, stand pipes, dummy plugs, rebuilt the rails with all new orings and nipples, new stc fitting, new ipr, new icp sensor. The truck has no leaks when pressure tested and has no hot start issues.
I swapped the pump a few days ago for a brand new ford unit and it will hold over 3v at wot now. Yesterday i swapped the ficm for a stock working unit in case the current ficm has some crazy tuning on it. Seemed to help some and icp was 3.2-3.5v at wot. The tuning is calling for about 2500us of PW i have tried ******** and warren diesel tuning same results with all tuning.
Any ideas where to go next? Seems to me that maybe now we have reached the limit of the stock hpop with this size injector.
