Lower coil spring pad bolt
KBMKVIII
Texas
Does anyone have a part number for the bolt that holds the lower spring pad to the front axle for 05+?
Have been looking for a while with no results even from the dealer.
A while back I used a leveling kit spacer that raises the lower pad and it came with new/longer bolts.
After two moves I can’t place the original bolts and I’m putting carli 2.5” coils in.
I believe it is a 2” m14 bolt but do not know if it’s fine or coarse thread.
Any help is appreciated as I may have to source through fastenal/grainger.
Home Depot and Lowe’s do not have this bolt.
Thank you!
‘96 7.3- Precision Turbo 76mm, Carrillos, Colt stg2, BAMF
‘16 CCLB 350 6.7- Tyrant 230, Low-temp therm, Bilstein 5100s
'22 CCLB 350 Platinum- Star white, Snow stg 3, Lo-temp therm, fox 2.0s/dual stabilizer, air bags, S&B, 22s/37s
