Lowering my 08 f350??
MorganM
SE Houston
2" PMF Traction blocks with bottom overload removed and 1 coil cut out of the stock 5600# coils
I like it- what side effects have you experienced from removing the overload? I guess the PMF kit prevents axle wrap/ hop?
Probably rides better, but have you towed anything?
Jonnydime
When I removed the top and bottom overload springs I installed air bags with a leveling valve and onboard air.
Jonnydime
Easy all you have to do is remove the center bolt and pull the spring out. I can't remember if I had to put a new shorter bolt in or if I reused the old one.
