main and rod bearings
gorace
On a 6.4 do mahle bearing run loose, compared to stock oem? Or are they all made by mahle? Coming up a little loose on my clearances, wanted to see if there was a option beside re grinding.
Mesa, AZ
I think ford gives you the option on over or undersized bearings if iremember rght from the last time i ordered a set. Whether they are available or not is another question though.
gorace
What do you like to see for clearances on rods and mains on a 6.4? .0006-.0035
