Milford
I am trying to trace down an injector issue in a truck and was wondering if anybody had a diagram for the large square ( I think its the 42 pin) connector that is on top of the driver side valve cover also for the IDM? I checked the resistance from the VC gasket side with injectors plugged in and I am getting anywhere from 2.8-2.4 Ohms which from what I have read is a little on the high side but I just want to go through the wiring and make sure all of that is good before anything else. Also all of the wiring when not plugged into the injectors comes down to .3-.4 ohms. Any helps with the diagram would be great guys, thanks!
