MCC engine parameters
Rueben1988
I'm what is the difference in engine 1 to 4 and what temps they mean when they say engine cold, engine warm and engine hot? And what the difference is in turbo vane control 1 and 2? Thanks in advance.
brewster
im also trying to decipher this. Im hearing 0 is warm stabilized temp and 4 would be in the coldest coolant temps. not sure what the different configurations are about. guessing a diff configuration of fueling and temps for the ecu to refer to.
ckrueg
Belding MI
The configuration tables are based on which injection event are active from what I've heard.
brewster
is it possible to config setting vs temp is the setting the mini max is on such as stock, tow, street etc. config 0 temp 0 would be on a stock tune warm engine, config 0 temp 3 would be a stock tune cold engine ??
ckrueg
Belding MI
I've tested that and it's is not the case. ******* was the one who posted that it was based on which injection events are active
