Mean Green 200 amp alternator
Extended Power
Have had it for a couple years, but my truck sits for 6 months a year, and I only drive it when it's sunny and dry out.
Reason for selling is I bought a bigger alternator, due to the fact I have too much electrical load, and it doesn't have enough time to charge the battery's back up.
Electrical load consists of:
Four 14" electric fans on radiator
One 18" Mark VIII fan on the rear mounted oil cooler
Aeromotive fuel pump
Air compressor (not on all the time)
Stereo system consisting of a JL1000/1v2, and a JL450/4v2
This alternator holds this load fine, but I'm adding two more JL450/4v2 amps, and another JL1000/1v2 (5 amps total, plus all electrical lad from before)
Alternator is in "Like New" condition, and works the same.
Comes in the original box.
$300.00 shipped.
Extended Power
I didn't change the length of belt, as it is not the "overdrive" size pulley.
I had one of those on my stock alternator...and still didn't have to change the belt length.
When I get home again, I can take a picture of the stock alternator and this one side by side. These are a bigger case size.
Extended Power
Here are some more pictures from this morning comparing the stock alternator to the Mean Green.
You can see the smaller pulley that was used on the stock alternator. I didn't have to run a shorter belt with it.
You can also see that the Mean Green is a bigger case size.
On the back, the stock terminal just unbolts, and bolts up to the new alternator.
Extended Power
ok thanks pm sent
I have another interested party in the alternator.
I sent you a PM with the same pictures as in this thread.
Please let me know ASAP if you want it, as he has PayPal ready, and I am leaving for Montana here within the hour.
Thank you.
