mercon v
gnxtc2
Bergen County, NJ USA
I go to my local Motorcraft supplier/distributor and buy Motorcraft Mercon V for my E4OD. Not a fan of multi-use trans fluid.
Motorcraft has specific fluid for Mercon LV, Mercon V, Mercon SP, etc, etc. Plus I can get 5 quart jugs.
https://www.fcsdchemicalsandlubricants.com/main/quickref/atf.pdf
https://www.fcsdchemicalsandlubrica...teering%20Fluid&category=Transmission%20Fluid
Mark
Would I be correct that I need to use Motorcraft Transfer Case Fluid since Mercon V is not approved to use in BW4407 transfer cases and Mercon ATF is not made any more.
Billy T.
gnxtc2@aol.com
