Mini maxx help
ChitownPS
Plugged in my mini maxx for the first time. And its stuck on initializing communication screen. ******d everything and now Im stuck and cannot download tune. Any help is appreciated
drunk on diesel
Used?
If new or used, try hitting the upper left button.
If used, power it up by the mini-USB port on the right and hit the upper left button.
Always load the tuner prior to touching exhaust or under hood components!
ChitownPS
New, I just got past that part. It was setup for a dodge. Now Im having problems updating sd card. No matter what I do my computer keeps saying "could not connect to update server"
ChitownPS
I started to install and it stopped me at the first cycle of key on key off and said to try updating.
ChitownPS
Morgan at midwest, I am going to call him tomorrow. I have tried for hours and cannot get it to work. I followed the update instructions on h&s website. Downloaded the updater.exe, but cannot open it on my laptop. I tried windows 10 and even recovered windows 7. Still get the same results as posted above. And I am connected to the internet
ChitownPS
Switched computers, updated complete. And now its downloading. Hopefully this helps someone in the future. Thanks fellas!
CoreyMS
If it still says unrecognized part number there is a post on hs forums on a work around.
ChitownPS
It downloaded tune, truck is up and running and feels awesome! Just not use to diesel stuff. Im learning, the hard way ofcourse. Reminded me of learning the hard way with mustangs back in the day. Thanks for all the help everyone!
ChitownPS
Which wire are you guys using to power up mini maxx on 13 f250? Im using the white wire with blue stripe. But it does not stay hot while cranking
W8KSK8
Same problem here.. Any ideas?
ChitownPS
I just left mine hooked to that wire. It works fine
