I was planning on just plugging the tuner in, loading the tunes, making adjustments under the truck and then unplugging tuner to run wires thru the dash and mount the pod holder above the vent by the pillar. Will it be ok to unplug or will it erase things when I remove it from the obd port? And how do I remove the dash piece to run the wire behind? Using this pod
http://sinisterdiesel.com/i-2124877...e-pod-mount-for-2008-2010-ford-superduty.html
