Mirror Bucket Removal?
Fenner408
Grinnell, IA
I want to paint my mirror caps, but my truck doesn't fit in the garage. How do they come off? I see two clips on the top and two screws lower, but they are behind the mirror glass. So I figured I'd ask the professionals before I broke something.
F15CrewDawg
Goldsboro, NC
Pull the mirror glass out with your hands. Mine were pretty in there when I did mine but it should pop right off. Then you can release the two clips at the top. After that just rotate the top of the cap toward the front of the truck.
Fenner408
Grinnell, IA
Is that for the two-piece, or the one-piece. Mine is the one piece, so I think I need to take some screws out, but Im not sure.
F15CrewDawg
Goldsboro, NC
It's very possible that I'm wrong but I thought they all had caps whether chrome, paint, or black plastic. This is how mine come off, if yours are different then it may still give you a better idea of how to go at it. If you're trying to split the whole thing then you'll pop both mirrors out and there are 5 (I believe) 7mm bolts that come out. Mine has 2 under the big mirror and 3 under the convex.
I pushed the mirror all the way toward the cab and pulled it out with my fingers to make sure I didn't crack it trying to pry with something hard.
I used two small flat heads to release the two clips at the top.
I held the two screwdrivers with one hand while I pulled back the top of the cap with the other.
The other two tabs at the bottom just slide right out.
Fenner408
Grinnell, IA
Mine are definetly one piece. Thanks for the pics. I didnt want to just start yanking on the glass not knowing how they come off.
Fenner408
Grinnell, IA
Got them all apart and painted. Thanks for all your insight, made it alot easier. I just wish I wouldn't have broke the F'n passenger side glass putting it together.
F15CrewDawg
Goldsboro, NC
Highly inconvenient that is, looks like they're about 70 bones from tasca parts, try Sunrise also. How'd she turn out? Been trying to get mine painted for a couple weeks but the local shops cant get the color mixed right.
Fenner408
Grinnell, IA
My local parts store can get tuem from Burco for 55-60. They didn't turn out to bad. It was just a bitch to tape off since they're one piece.
