modified dt360
jimdawg185
I might need to call ya Chris, this is now making my brain hurt. I gotta sell a whole lotta oil to buy this, who needs their oil changed???
swamp_ratt
hudson, wi
Stock head bolts will hold 300psi of boost and I use a different lube on assembly now. Stock head bolt torque is 165 lb/ft with arp lube. The stuff I use achieves the same stretch at 15 percent less torque and these are torqued to 165 again. The completely stock bottom end will hold 1500hp at 5500rpm. With the ATI super damper, you could possibly see 6000. This motor was designed and built to run the turbos I mentioned at 900 plus hp as a daily driver/tow rig/occasional drag truck. I even have the perfect set of triples spec'd out of anyone is interested. A lot of time and thought went into the setup of this motor!
jimdawg185
Ahh, makes sense now. Didn't see to many of those in the fleet...
Rubenk
KCMO
Damnit I sold mine back in Feb! Would love to see this in a deuce though!
Jimdawg I was just wondering about your excursion project on PSN recently.
jimdawg185
It's been sitting for a while. I have been quite busy with the 6.4...
I might finish it low horse power and just sell it. It will make a good base for a really nice truck for someone.
