MPD S475 Single Pricing
Mike@MPD
Pasadena,MD
Here you guys go
Kit includes
Custom log style MPD stainless manifolds
Bullseye S475 75/83 .90AR with Batmowheel
Downpipe
Custom Stainless upipes
MPD Custom Air intake
All mounting hardware and lines
For the first 5 kits pricing is $4250
Normal Pricing will be $4700
Headstuds and built trans are required
working on a whole kit with injectors and Pump
Kit has made 848 hp with 100% Injectors and II pump with Airdog II and Elite Regulator system
08SUPERKING
Wow very good prices and is there any plans in making a twin set up like this kit...
Keep up the great work... Very clean set up....
oneturboforme
Hey mike did you guys ever figure out a price on just your manifold? Any planys on runing different size s4s like a 472?
Mike@MPD
Pasadena,MD
The s372 is pretty much a s472 with a smaller front cover, ill talk to craig about the mounting kits. The S372 flows 1350 CFM, which is more than enough for 900+hp
UPINSMOKE
Dundalk, Maryland
So essentially... With this kit, industrials pump, studs, fuel system, nos, and trans work I could have a 10 sec Reg cab??!?!?
Bargain...
oneturboforme
Umm didn't Craig run 11.35 on his crew cab with 20" rockstars? Without nos? I may be wrong but I thought thats what I read.. a reg cab short box has to be close to high 10s then right?
Jeff@Spartan
Georgia
My guess is that with a good 60 foot and a light weight RC/LB, 10.8-10.9 would be very possible. If Craig's truck weighs 8200-8300 lbs, you could get a 6300-6500 lb truck down the track pretty quick. Craig's truck looked like a turd of the line. Can't imagine that 60 foot was too impressive.
