MTW Stage 3 Boost...
GatorBaitR6
Gray, TN
Anyone out there running a stage 3 MTW what do you see for boost...? Im only seeing 32# and don't know if thats as high as it gets or maybe thats the highest that will read out via the OBD2 port onto my TS...
GatorBaitR6
Gray, TN
That's what I was thinking/hoping. Guess I'll be in the market for some gauges. :/. That's what the ts is supposed to be for lol. Well at least I already have a boost line run for my water meth controller that has **** the bed so it's not being used.
GatorBaitR6
Gray, TN
Well the email reply from MTW says he gets 50-60# from his sooooo yea idk. Garage door you reading from a mechanical gauge?
GatorBaitR6
Gray, TN
I luckily enough had a jerryrigged boost line from my watermeth system that failed so I just hooked the gauge into that. But i keep blowing the seal apart around 30psi so I can't find out. Gonna have to put some rtv on It
GatorBaitR6
Gray, TN
Well on full throttle I only see 35# until the converter locks then I saw up to 40# but I was comin up on a civic rather quick and had to let out of it.
