My boss says not to worry about it??
chris89
So I checked my codes the other day and I have a soft code for the #1 injector. I see that RiffRaff sells the UVC gasket, connect and harness all separate. Should I buy them all or do I just need one of them??
davey99ps
Waterford WI
What's the code? If you think you have an injector going bad, you can try swapping it with another 1 of your injectors an see if the code follows. Have you pulled the valve cover to make sure the plug for that injector isn't coming loose?
silverpsd_06
Wellsville KS
What Davey said check connections if that does not work swap holes see if it stays with the injector our the cylinder.. Should spell it out from there
chris89
I put the 180/100s in and it's still there the plug was tight if I remember right. I'll pull the codes again and write them down in here.
Arisley
Arlington, Texas
Before you just go replacing parts, grab a multimeter and ohm out the connections. If you don't have one, you can buy one at Home Depot for half the price of a gasket or a UVCH.
Also, if you don't have one, you need one. A very important and useful tool. You can get a really decent one that will do all you need for around 30 bucks.
Sent from my truck while eating, adjusting the radio and passing a Mustang sideways.
chris89
I have a fluke and have the paper on what to test at work, but I've read that the ohm test isn't real accurate?
chris89
Said because the high voltage from the IDM and the low voltage from the dvom. The truck runs good with no missing.
golfer
If you don't have a CEL/SES light illuminated constantly...then the wiring (& IDM) is fine...assuming you are running Ford Motorcraft wiring.
