My Build Thread-American Hogger
blk350on20s
Thanks guys. And Mink LOL.
That is my plan. April 4th is the weekend. Gonna run the paddles in the all tire class.
JEEPSTER401
Should be good snow again this year. Does the all tire class run up on the first hill from the right? Last year on the diamond hill where the big boys were running was good to watch, to bad it took them so long between runs. Might have to try that with the Jeep this year if the tranny parts get here in time. Sorry for the side track back to the build!!
blk350on20s
No they run up the second from the right then the unlimited class races up the face.
blk350on20s
Final machining and supports are not done but she's ready for piping
JDub
Hooper, Utah
Don't want to read the whole thread, what turbos did you decide on? Atmo appears to be a s591? What about the high pressure?
Sent from my DROID BIONIC using Tapatalk
blk350on20s
Buddies snap chat. LOL
Screwed up a v band on the hot side making the pipe fit for the T6. Need to order a 5" v band....1 side aluminum and one side stainless for the HP intake and need a 3.5" stainless end for the pipe side of the LP outlet. I guessed wrong and got 3".
skevac
Michigan
Not only is this an awesome build, but you must be one tough SOB to work in that shed with no insulation with the winter we've been having here in Michigan! Looks like you need a bigger wood stove LOL. Good luck. I hope you make the cut for the DPC.
