my mild build.
jugger13
Try Jefferson State Diesel in Redding. They have a dyno IIRC. The truck is looking great!
Thanks wayne.
im hoping to be at or over 700.
Were there gains with the 59 hp over the stock hp while running the 72 atmo?
Diesel23
NWI
Good question bud , i was under the impresion that the hp side didnt really do much for HP , but i was always thinking it would help out a bit !!
Wayne
Twin Falls, Idaho
I haven't tested the difference with anything but 60 hp nozzles, but it lowers back pressure, and boosts power by an additional 20ish hp depending on the setup. Heavier fueled setups will likely see more. I should also warn you about JSD as I hear their work quality and parts are sub-par, but that's only a rumor somebody may want to clear up if I'm incorrect. They should be fine for the dyno though.
jugger13
Thank you good sir, that's good to hear.
Looks like I have a sporting chance at cracking the 700 mark with the parts I got and the elevation I'm at witch is 1200-1400ish.
