Need help! 12 F350
bigaF250
Grand Junction, Co/ Midland, TX
Our 2012 f350 has started throwing fits. When in regen, climbing a hill and once up the hill the turbo will start to surge the the whole truck starts jumping around and knocking pretty good. Almost like a bad injector and turbo both. Any ideas? Local Ford dealer says they can't do anything either until catastrophic failure or until I can replicate the problem with them in the truck. This shop is an absolute nightmare to deal with by the way
Unfortunately, thats how they all are. wont just take your word for it.
Mpoage
OKC, OK
Well if it has no codes and can't duplicate the problem how do you know what's wrong. You can only throw so many parts on while under warranty before Ford starts watching it closer.
Central Illinois
Might want to read this TSB....MAY be what you have going on. Hope this helps!
2011-2013 F-Super Duty - 6.7L Diesel Engine - Runs Rough/Misfire During Exhaust Regeneration Process
See TSB: 13-05-09 for details. 13-05-09
Some 2011-2013 F-Super Duty vehicles equipped with a 6.7L diesel engine may exhibit a runs rough/misfire condition only during the exhaust regeneration process. This condition typically occurs on light throttle tip in between 64-113 Km/h (40-70 MPH), and will not set diagnostic trouble codes (DTCs). The concern may be intermittent and a knocking noise may be present during the concern.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Step 1- Did the customer indicate the message center displayed a Cleaning Exhaust Filter message prior to the concern?
Yes - proceed to Step 2.
No - this article does not apply. Refer to the Powertrain Control/Emissions Diagnosis (PC/ED) manual for normal diagnosis.
Step 2- Using Integrated Diagnostic System (IDS) or equivalent, retrieve DTCs from the Powertrain Control Module. Are DTC's present?
Yes - this article does not apply. Refer to the PC/ED manual for normal diagnosis.
No - proceed to Step 3.
Step 3- Remove the left hand cylinder head. Refer to Workshop Manual (WSM), Section 303-01.
Replace all eight (8) exhaust valves and valve seals.
